Ir para o conteúdo principal
Why do I keep shorting out the starter solenoid?
Put brand new starter in my car, worked great for about two days then it wouldn't start, so I replaced the battery cables thinking that was the problem nope, not it, at first I didn't think about the starter cause it brand new, so I tried to jump it maybe it's the battery nope come to find out it's the solenoid so replaced it again brand new starter and solenoid and again worked for two days then just quit someone mentioned to me that I may have a low or high voltage short somewhere any ideas where this could be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Check to see if any of the wires going to the solenoid are missing insulation. In most cars, the wires going to the starter are always grouped really tight and very close to the engine block. It doesn't take much movement for a slightly bare wire to short things out in this situation.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
andres ray será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 3,787
