Battery is still dying at 20-30% after reaplcement
Hello,
I had battery problems with the original battery on the iPhone 6s (battery would die randomly) and I ordered a replacement. After replacing, I drained the battery to 0 and charged it to 100% and it still dies randomly.
The only difference is that it dies consistently around 20-30% and when I turn it back on, it has the same percentage as it did when it died, whereas before with the old battery, it would fluctuate (for example the phone would die at 15 but turn on at 30).
Also, if you wait a couple of minutes, you can turn it back on but it turns off right away without a charge.
Esta é uma boa pergunta?
Where did you get the replacement from? All I can say is that it is another bad battery.
por Ben
from iFixit. I restored my phone and updated to the new iOS so hopefully that will fix my problems.
por Tony Dinh
Try taking a rear camera photo with flash on. It should shut off / apple logo when the battery is not full around 20-50% if it does it could be the battery being at fault.
Though I wouldn't try anymore after that as like Tom Chai said, faulty power IC if it is the case.
por Ben
