Ir para o conteúdo principal
The Nikon D7000 is a 16.2 megapixel DSLR launched in 2010.
37 Perguntas Visualizar todos
How can I dissasemby the dial in my Nikon D7000?
Hello, I have a Nikon D7000
The dial (S, A, M, P, etc) has broken and only the axis remains. I can move it and change the function, but I would like to get the rest of the dial to see how it is and make a new dial with a 3d printer. But I have no idea if you have to open the camera or if the dial comes out with pressure.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@akilesroto , Mode dial/button removal, I posted a couple links below of tear downs on your camera which should show how to access the button for removal. Also if it comes to it last link replacement dial, which you can also do a search for a lower price. Good luck.
Nikon D7000 Shutter Assembly Replacement
Nikon D7000 Motherboard Replacement
http://www.ebay.com/itm/Original-Mode-Di...
Imagem de Nikon D7000 Motherboard
Guia
Nível de dificuldade:
Moderada
30 minutes
Imagem de Nikon D7000 Shutter Assembly
Guia
Difícil
45 minutes - 2 hours
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Akilesroto será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 923
