Ir para o conteúdo principal
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
Why is my 3DS Not Charging?
I recently took out my 3DS and upon trying to charge it, the charging light would not appear. I assumed that the system's charger port was broken, which I researched could be a couple different issues: the two pins on the inside of the port could have been bent, and would need to be bent back into shape to get it working. That didn't do it, so I opened the system up to see if there were any broken connections to the port. They were all in tact, but I applied extra solder to each of them just in case. It didn't fix it. Here are some pictures:
Are there any other reasons the system wont charge/the charging light wont appear? Any fixes?
Thanks in Advance
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
I have the same problem to,but i never opened my 3DS to chek whats wrong.
por
Adicionar um comentário
1 resposta
I would suggest taking a look at the devices battery. You can buy them on eBay for about £5 new. Possible but unlikely one of the fuses in your device could be fried.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Hays será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 724
