Ir para o conteúdo principal
Reparo e suporte para os controles que vêm com o PS3. Lançado em novembro de 2007 (somente no Japão) e 2008 (outros países), este controle de seis eixos alimentado por bateria de lítio (CECHZC2) é fácil de reparar.
My PS3 controller will not turn on at all?
My PS3 controller wont turn on - no red flashing lights - no response to being charged or reset. Also, when the controller used to work, I accidentally hit it - not hard - against my fan and then it sounded like something was broken inside of it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
find a set of star screwdrivers and open up the controller then detach the battery connector from the board of the controller then try connecting it with the usb to your console and do a reset on the pad it should work if it does probably your controller is dead
Esta resposta foi útil?
Pontuação 1
8 comentários:
Ok will try thank you!
por
So am i pretty much just removing the battery
por
then it should be a board issue
por
suggest u get another controller then
por
Exibir mais 3 comentários
Solved ! Get the same usb type cable with data support.. like printer cable so that your ps3 controller can be detected by laptop/PC . You will see the controller lights blinking the moment you insert in the PC (install the drivers first or win 8 which has pre-installed drivers for ps3 controller). Insert and remove couple of times the USB cable until your ps3 controller is able to start up (don't start playing immidealy let it charge first) ..then charge normally . I once tried this with dead iPod it worked and it worked with my PS3 controller too.
Pontuação 0
My ps 3 controller is not working not blinking light
Pontuação 0
Adicionar a sua resposta
SilverLordGamer512 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 10,170
