My router won't turn on
I unplugged my router and reset it this morning and it still wasn't turning on, how do I get power back in my router
Esta é uma boa pergunta?
I had some good luck on the mine one, and finnally it is working again.
Check the other post:
Esta resposta foi útil?
Before resetting the router, press the "Power" button back and forth to see if it powers on. If it doesn't, press and hold the "Reset" button on the back of the router to restore the device to the default factory settings. After resetting the device, press the "Power" button to turn it on.
Please check the power outlet where you have attached the router. Because insufficient power supply wont allow the power LED or any other bulb to light on your wifi router. Next, if you find the electric outlet is working, try to check the router's hardware using test pin and confirm that there isn;t hardware issue.
After your router's passes the above steps, if you still don't see any LED lightning on machine then, reset the wifi machine by pressing the RESET button at the back of the router.
Important: With this action, your device will lose all the customized settings and may display green flashing light.
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 4,847
Hi, Have you proved that the power adapter is working? Have you checked the wall outlet is working? What lights if any are showing on your router? What have you tried to get it working?
por jayeff
