Ir para o conteúdo principal
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
37 Perguntas Visualizar todos
Only Fan turns on when holding power button
Hi!
So my problem is, that my Lenovo Y50-70 wont turn on at all. Only the fan starts when holding the power or recovery button. (Fan only works for 10 secs. then the whole laptop is quiet, USB 3.0 Ports has Voltage the 10 secs. fan is running)
would be nice if i get an answear here.
Maybe the Problem is electrostatic charge. but since i cant remove the battery i ve no idea how to make a discharge.
Regards,
flo071
Esta pergunta é pertinente?
Pontuação 0
1 dos comentários
Did you ever find a solution to this? I just ran into the same issue...
por
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
One method of doing a hard reset is to remove the power cord and press the power button for 20 seconds.
Another method is, with a low battery and while charging, press and hold power button until the battery LED is off, then immediately pull the cable, release the power button, and try to power it on again.
UPDATE: Ok, I know this is an old thread but since that didn't work - have you checked the RAM?
Esta resposta foi útil?
Pontuação 1
7 comentários:
The only problem is, that the battery is not removable.
But thanks anyways for your fast answer. :)
por
No problem. Give it a try though, this advice is specific to your model, so it might fix the problem.
por
tried both of them. Sadly nothing worked. Is there any other method?
Thanks!
por
flo071, did you ever fix this? I just ran into the exact issue...
por
Matthew, have you checked your RAM?
por
Mostrar mais 2 comentários
Adicionar a sua resposta
flo071 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 2,366
