Ir para o conteúdo principal
The Wii Remote is the original, primary controller for the Nintendo Wii game console released November 19, 2006. The model number for the original Wii Remote is RVL- 003.
Can't get Wii Remote to turn on, even with new batteries
My Nintendo Wii Remote will not turn on even with new batteries. It blinks but turns right back off.
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Pergunta mais útil
If your Nintendo Wii Remote will not turn on, use this Nintendo Wii Remote Won’t Turn On problem page for possible causes and solutions.
My best suggestion would be to open the controller up and inspect for any corrosion or water damage. From the sounds of it, this is probably the case. If the inspection doesn't come up with any leads then the only other suggestion I could make is replacing it with a used one off eBay. They're very cheap now and it's the most economical move to save time and/or money.
Good luck.
Esta resposta foi útil?
Pontuação 1
I've had my Wii remotes since the Wii first came out and have had this problem with all of my remotes, its usually because the battery contacts have worn out over time. The best fix is to spray some contact cleaner on the battery contacts, rubbing alcohol also works, if its visibly corroded you can use some sandpaper and just scrape it a little bit.
Pontuação 0
You might have to re solder the battery joints to the Wii mote, thats what happened to my Wii mote.
Pontuação 0
Adicionar a sua resposta
number1nana será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 30
Últimos 30 dias: 123
Ao todo: 18,799
