Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Perguntas Visualizar todos
Why dos my computer make noise when tilted?
Does your MacBook Air also makes a noise like there's sand inside while tilting to the left and right. I'm pretty sure it's the keyboard but I wanted a community opinion, because I don't know anyone else with the macbook. It's a brand new computer, 4 days old.
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
Do you mean a rattling noise, if you shake it? If so, this would be the plastic keys shaking left and right
por
it's like that yes, it's a strange noise. My friend has the MacBook Pro and it does not make that noise, so that's why I find it strange. It's while shaking and while you tilted 90 degrees to the right and to the left. But what I find funny it's the you don't see the keys moving. So is it the inside mechanism of the keyboard?
por
Yes I think it is either the mechanism or the key itself. Just checked, my MBP doesn't make a noise, but just grabbed a 2011 MBA 11 and it does, so I guess it is just a difference in the keyboards. Hopefully it isn't too annoying :)
por
I think it shouldn't do as it is a 1000 euro device but thank you very much for taking time to help . I guess it's a MacBook Air thing. It's just good to know it's not a problem but a "feature" ;) . Thank you very much once again.
por
Adicionar um comentário
1 resposta
The macbook air's use the older symmetrical fans that sometimes make noise if you throw them off it's center. Tilting your computer in mid air definitely does this but overall It's no big deal. The fans are tough enough to withstand a lot more pain than shaking your computer around.
Esta resposta foi útil?
Pontuação 0
1 comentário:
it's not the fans, as it also does the noise with the computer turned off, I think it's really what @Reece suggested on a comment in the question. But thanks anyway for your help.
por
Adicionar a sua resposta
jfgcf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,794
