Ir para o conteúdo principal
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
20 Perguntas Visualizar todos
Can't hear caller on either phone
have 2 phones. can't hear callers after answering, but they hear me. all connections seem good.
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Nope, it wasn't a mute matter. But I ended up calling AT&T and after about an hour a woman on the phone who sounded Filipina cleared the issue up remotely by rebooting my modem. Now everything is fine with both units. Thanks for your input.
por
Adicionar um comentário
1 resposta
Does the phone have a mute button? It should reset after hanging up the call, but see if it might be stuck. I assume this happens with both handsets, correct? That renders the mute button idea a long shot, but have a look. Also, does the base station have a mute button? If that's on, that could cause this.
Otherwise it sounds like the base station has the problem, and it's probably difficult or impossible to fix.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
John Willis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 10,592
