Ir para o conteúdo principal
American Edition released in 2013, identified by model number X502CA
11 Perguntas Visualizar todos
Stuck in bios mode after updating to windows 10
So yesterday I was updating my computer and it was downloading windows 10. It got all the way to 100% before it froze for about 2 hers. When I restarted it, it immediately went to Aptio Setup Utility. I have tried everything mentioned. Taking it apart, turning it on and off again, enabling and disabling you name it. Before updating my computer there was literally nothing wrong. Now it seems Im &&^&@@. Has anyone else had this issue when updating?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Go on another working computer and make a Windows 10 install/recovery media by going to this link and following the instructions
https://www.microsoft.com/en-us/software...
Insert the disk into the computer and boot up. In the bios, go to the boot tab and select the usb drive under boot override.
You should be booted into the windows recovery disk. Do not remove the disk. Go to repair my computer and select automatic recovery. If that does not work, then you will need to perform a fresh install.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yup .... that's the only real way
por
Adicionar a sua resposta
Frank Rojas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 962
