Ir para o conteúdo principal
No power and blinking light
Hello my Alcatel one touch ideal (4060a) won't turn on, had water damage, cleaned it checked for burnt stuff etc but shows no power. Only sign of life is blinking light.
Esta é uma boa pergunta?
Pontuação 0
23 comentários:
Bump........
por
Really need to recover data
por
Plz help meh
por
@gigabit87898 did you replace the battery?
wet batteries are usually the first thing I replace. There usually junk . What did you use to clean it?
por
@jimfixer 90% isopropyl alcohol
por
Exibir mais 18 comentários
Adicionar um comentário
1 resposta
Have you tried to hard wire it with a broken charger? I have the same problem with an alcatel phone too. I haven't tried it because I just barely tried turning it on after letting it dry out, but plan on cutting the en off one of my broken chargers, and putting the red wire in between the battery and the phone where the “ + “ is and the black where the “ - “ is. If it works, then you know the problem is the
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Gigabit87898 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 5,638
