How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
Esta pergunta é pertinente?
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
Esta resposta foi útil?
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
On your RCA tablet go to settings, click on display and then configure HDMI settings.
What do you do after or even how do you configure HDMI settings
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 12,718
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
por boogityboo
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
por boogityboo
cant get it to work either way.what to do ?
por Wess Reddish
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
por jillherbert1
I've got it working, see my answer below.
por jillherbert1
Mostrar mais 1 comentário
