Ir para o conteúdo principal
Phone stuck in a boot loop
The other night my phone did an update and when I woke up the next day it was on the Huawei logo that appears when booting the phone up, I took out the battery after 10 minutes of it staying on the logo and turned it back on and the same thing happened again, I have entered recovery mode and done a factory reset and wiped the cache partition, I cannot find a download for the right firmware. Any help would be greatly appreciated
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Same here mines stuck on logo screen will not turn on tried everything
por
Adicionar um comentário
2 respostas
Use a small paper clip in and in the back of the tab is a small button by the headphone jack and quickly click it with the paper clip then turn it back on
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you, I found the hole and placed a paper clip in it and pushed but it didn't click or move at all, If you have any other tips they would be much appreciated
por
follow instruction here
Pontuação 0
Adicionar a sua resposta
andrews122 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 10,814
