Ir para o conteúdo principal
Um laptop de 11,6" com Wi-Fi e 4 GB de RAM. Identificado pelo número de modelo VPCYB15KX e pela referência PCG-31311L. Fabricado pela Sony em 2011.
Vaio LCD screen issue
How Do I troubleshoot a notebook LCD screen issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
IMPORTANT: If the LCD is all one color or there are large portions which are all one color, tilt open and then close the LCD screen. If the colors change or return to normal as the LCD is moved or lightly tapped, other than the normal changes in brightness as the angle of viewing changes, the video cable has become crimped in the hinge and the notebook will need service to resolve this issue.
For all Sony products (EXCEPT VAIO computers): To send your product to a Sony facility to be repaired or to check the status of the a repair, visit our eService web site.
For VAIO Computer products: Please call 1-888-4SONYPC (476-6972) for service information for your product. To check the status of your VAIO product repair, have your phone number or Best Buy service number available and call 1-800-433-5778.
Ensure the brightness of the LCD has not been turned all the way down using Fn+F5 and the arrow keys. The RIGHT ARROW key is used to increase brightness.
The computer may be in video standby mode. Press any key to activate the display.
Ensure the AC adapter is properly connected to the computer.
Ensure the battery pack is fully charged.
Disconnect any external display, all external devices, and remove all PC Cards.
Restart the computer.
NOTE: Disconnect the AC adapter and battery pack. Push and hold the power button or slide and hold the power switch, depending on the model, for 30 seconds. This will ensure the computer is completely shutdown before attempting to restart the computer.
Press the Fn+F7 keys to cycle between the video output modes.
Reset the BIOS defaults.
Ensure the RAM memory modules are seated properly.
NOTE: Instructions on accessing the RAM memory modules are included in the user guide. Manuals, Specifications and Warranty information for your Sony product is available online.
Determine if the LCD screen is physically damaged.
If the issue is still unresolved, service may be required.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Farlow será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 24
Ao todo: 740
