Ir para o conteúdo principal
Lenovo's fourth generation Yoga laptop debuted in November 2015. The Yoga 700-11ISK is a hybrid tablet-laptop that features a 4-in-1 design, 8GB of ram, a 2.5 solid state drive, and an Intel® Core™ m7 Processor.
Why can't I charge my computer?
I have a Lenovo Yoga 700. When I plug in my computer, I have to hold the charging chord at certain angles to make it begin charging. Does that mean that I just have a bad charging chord? Or is this an issue with my actual computer?
Esta é uma boa pergunta?
Pontuação 2
3 comentários
It's the charger itself, I've had this issue with two chargers.
por
Mine seems to be at the cable to computer connection and I also have to move this connection around to get a charging connection. Still don't know what the actual problem is.
por
Hi @ John Jarvie,
It may be that the DC-In connector is loose from the board that it is mounted on and only making intermittent contact.
Fortunately this is a separate board in your laptop and it is easier to replace this than having to remove the motherboard to replace it.
Use the information from the Chosen Solution below to find out how to access the part and if it needs replacing how to get a new one.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
It seems from your description that the DC-In connector is either damaged, loose or faulty.
Use a strong light and a magnifying glass to visually inspect the port and check that the pins are not bent and are straight and parallel with each other. Also check that there is no dust or lint caught in the port. Do the same for the charging cord.
If everything seems OK or even if the pins are bent etc., read on:
First is your laptop still covered by the warranty period? If it is consult the documentation that came with the laptop as to what you have to do to make a warranty claim for a repair or replacement. They may dispute the warranty claim if the pins are bent or if the connector is loose claiming user abuse, just a thought on my part, no proof they will.
If it is no longer covered by the warranty, here is a link to the service manual for your laptop.
https://download.lenovo.com/consumer/mob...
Scroll to p.48 to see the pre-requisites and procedures necessary to remove the DC-In cable (with connector).
Here is the part number of the connector, 5C10K57005. If you search online using just this number, (do not add Lenovo or connector or anything else to the search term as it will skew the results) you will get suppliers of the part.
Here is a link to just one supplier. It is shown just to give you an idea of the cost. There are others if this one doesn't suit you. Just search for them. (see above re search term).
Lenovo IdeaPad Yoga 700-11 DC-IN Cable - 5C10K57005
Hopefully this is of some help.
Imagem de Replace a dirty, corroded, or damaged DC-IN cable and socket.
Produto
$42.99
Esta resposta foi útil?
Pontuação 4
1 comentário:
I have this problem too . But my computer is Lenovo yoga 700-14ISK. I can replay as part number 11ISK ?
por
Adicionar a sua resposta
nick1037 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 60
Ao todo: 8,381
