Why cant I receive txt message
why cant i receive txt messages
Esta é uma boa pergunta?
Pontuação
0
If you've checked all obvious stuff like you're not in airplane mode, sending to valid recipient, etc, I would check the APN codes for your carrier and make sure your device is set to correct codes. I have had this issue many times before with MetroPCS. You can find the correct APN for your carrier by searching Google or calling your carrier. HOPE that helps.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 79
