Ir para o conteúdo principal
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
My phone doesnt open.
I cant turn on my phone. Whenenever I plug it to the charger it only blinks, i tried to reboot it but the logo doesnt appear
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
did u try to remove your battery,sim and put back again?
por
Adicionar um comentário
2 respostas
your phone shouldn't open. It should stay shut.
but to get it to turn on, put it into recovery mode, and then from the menu, hit reboot,
if it doesn't even get to recovery mode, you've got a dead battery. replace it.
Esta resposta foi útil?
Pontuação 0
hi i tink there is no minimum voltage in your mobile battery... try to boost your battery or change the battery it will work..
minimum voltage in battery is 3.6 below the 3.6 volt phone not turn on
Pontuação 0
Adicionar a sua resposta
Gedine Sange será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 217
