Trackpad unresponsive on half of trackpad
I recently replaced the keyboard, battery and trackpad on a macbook pro 15" mid-2009 unibody. The keyboard and battery work fine, but I am finding issues with the track pad.
The trackpad is able to click, but it is unresponsive to mouse movement in the upper half of the trackpad. I can only move it left and right if I use the upper half of the trackpad. I am able move the cursor in any direction on the lower half.
I have tried adjusting the main clicker screw, but I don't belief that to be the issue because it's able to click anywhere on the trackpad just fine.
The mounting screws are tight in their place.
I think I received a bad part, but I want to explore all the options before returning the part.
Esta é uma boa pergunta?
1 comentário
I replaced the cable with a spare, same issue. I believe it's either a bad part or the logic board itself is somehow damaged. Thank you for your answer!
por battaninic
