Ir para o conteúdo principal
O Nokia N8 é o primeiro dispositivo a rodar o sistema operacional móvel Symbian^3 e o principal dispositivo da Nokia de 2010.
Phone can't read the SIM
This phone had been a wonderful service until few days back. After changing SIM it can not recognize the SIM. Shows off line. I think there may be a problem at SIM tray. I had given the set at Nokia service center in Dhaka, Bangladesh. They said they don't have any spare parts available at the moment. How can I fix it.
Dr. Ahsan Kabir
Consultant Urologist.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Did you test the phone with different SIM cards, if the problem is the same you need a fix from a service center. Most likely the SIM tray is broken and needs replacement.
Regards
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
drbabul será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Ao todo: 909
