Why is my disk not reading?
I place my disk in the DVD player but the screen says "cannot read." What should I do?
Esta é uma boa pergunta?
Hi! Sarah
Check if the disk is clean and scratch-free (you can clean with alcohol), maybe you use Bluray disk and your DVD Player can't play Bluaray disk. If is external DVD Player check if the cable are good or you USB port it good too, try another USB port. Good Luck!!!
Esta resposta foi útil?
How to fix portable DVD has stopped dynamo and error disc
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 440
