Ir para o conteúdo principal
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 Perguntas Visualizar todos
The screen rotates the wrong way
Hi, the screen of my iPad mini 3 rotates the wrong way, exactly, when the ipad is in vertical position the screen rotates in horizontal position and viceversa. I have already reset my ipad to the factory settings but with no results. Is there any solution for this defect? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
That's a strange problem did you try to lock the screen? While on the home screen Swipe up from the bottom from the screen which will display some options, the lock icon is at the top of this option box and has a lock with a circle around it. See if that helps!
Esta resposta foi útil?
Pontuação 0
hello, I have already tried to block the rotation of the screen, but this only locks the screen in a certain position, however, I would like to eliminate the problem permanently.
Pontuação 0
Adicionar a sua resposta
adinmoldova será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,770
