Does anyone have the schematic for Altec Lansing acs33?
The sub stopped working. All else works normally. The woofer checks ok. Would like to troubleshoot amp.
Esta é uma boa pergunta?
Sometimes it could be due to bad IC chips, transistors, or failed capacitors, etc.
If you have a multimeter, it would be a good start.
Esta resposta foi útil?
I was wondering if I can wire my Acs 33 sub to work with None Ace 33 speakers or without out. What is the audio in pins on the 6 pin din?
Josh my altec lansing vs5121 was 120v however the audio board used 18vdc! So now it's running off a ryobi battery! I added a mp3 blutooth card reader! It's awesome. I can get a acs33 for 6$ used. Would you happen to know the operating voltage of the board in that unit?
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 24
Duração total: 1,038
1 comentário
did you get any ACS33 schematics?
por stanley Siu
