Power button doesn't work anymore
Power button stopped working a while ago, so the computer was never turned off until it was on battery power and died. Now it will not turn on when I press it, i've tested both memory chips and the HD still works fine.
I don't know if this is important, but in complete silence I noticed that if I press the button I hear an ever so slight ticking noise, just a little faster than a clock (not from the HD I think) and a very very soft hum.
Any ideas?
Esta é uma boa pergunta?
2 comentários
I replaced the whole top case. Problem solved. If there is a way to just replace the power button I will never know...
por spacec0w
There's no easy way to replace just the power button. It pretty much requires that you damage the top case. You did the right thing by just replacing the top case.
por Josh
