Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Perguntas Visualizar todos
Is it possible to install a bigger HD into an 30gb iPod?
I'd like to know if it's possible to upgrade my iPod's HD once that i'll have to substitute it anyway.
So, I want to know if I can install a 80gb (for example) HD into my old 30gb iPod video (5th generation). In that case, is it possible to upgrade the battery to, or the batery for the 80gb iPod is to big?
Update
Why is necessary to change the headphone jack and de rear panel to?
By the way, i'm sorry for my poor english, but i'm from Brazil
Thanks for your patience!
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Actually, you can also install up to a 256GB SSD, but you have to make sure it is of the 3.3V type, not 5V.
por
Adicionar um comentário
3 respostas
Solução escolhida
Yes, you can upgrade to the 80 GB hard drive. You just need a few other parts also:
60/80 GB Headphone Jack
60/80 GB Battery
80 GB Rear Panel
Rubber Bumpers <---forgot about those the first time through
That is all you need to make the swap.
Update
You must replace the Rear Panel because the 80 GB drive is thicker than the 30 GB and your 30 GB rear panel won't fit over the 80 GB drive. Also, this is the same reason you need the 80 GB headphone jack. It has a longer cable to fit around the thicker 80 GB hard drive. This applies to the battery as well.
Imagem de iPod Video 60/80 GB Headphone Jack & Hold Switch
Produto
$24.99
Imagem de iPod Video 60/80 GB Rubber Bumpers
Produto
Imagem de iPod Video 80 GB Hard Drive
Produto
$48.99
Imagem de iPod Video 80 GB Rear Panel
Produto
$9.99
Imagem de iPod Video 60/80 GB Battery
Produto
$13.99
Esta resposta foi útil?
Pontuação 11
1 comentário:
You almost got it matt- you forgot the rubber bumpers, those are essential, for a complete list of the parts you need check out this wiki page.
Pontuação 1
A fast and easy way to upgrade your iPod's storage is to get an iFlash mSATA adapter and an mSATA SSD of your choice of capacity. I've done this with my iPod Video and now have 128GB of storage available (more to come down the road!)
Pontuação 1
Adicionar a sua resposta
Artur Lulai será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 8,063
