Ir para o conteúdo principal
A Acer entrou no mundo dos laptops em 1997, quando comprou a divisão de PCs móveis da Texas Instruments.
1682 Perguntas Visualizar todos
How to replace an Acer 5100 touch pad?
My mouse/touch pad and keyboard do not function. I can not enter any commands, the cursor does not move. How do I remove and/or replace the touch pad?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Before replacing the touch pad, try plugging a USB mouse or keyboard into the laptop.
If this works, it may be that the keyboard and touchpad do need replacing.
But this seems unlikely since on the Acer these units have completely separate interface units on the main board.
Removing the keyboard on Acer is fairly simple with only a screwdriver.
There are two screws on the bottom of the case, sometimes marked with a keyboard icon. Remove them and the keyboard should tilt out. Be careful not to yank the brown ribbon cable.
I suspect you have either a software problem, or a partially damaged main board.
Try booting from a "live" distribution like damnsmalllinux.org on a flash drive and see if the keyboard and touch pad work.
Good luck, hope you get this fixed.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Eleytz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,825
