Ir para o conteúdo principal
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
Purchase Apple Watch (42 mm) LCD Screen and Digitizer?
So i have a series 1, 42mm white apple watch. I bought it with a cracked screen. Now i'm looking to get the screen replaced and i have much practice replacing and fixing iDevices, so i'm comfortable doing this my self. But i cannot find a place to buy the 42mm LCD+Digitizer combo. I looked here on iFixit (my favorite go to website when needing help) but it says "Not for sale". Whats up with this? Does no one make replacements for the 42mm version? its there a legit way i can get a OEM replacement? Or a very good knock off?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Here is another supplier you can get it from lcd/digitizer assembly.
http://www.unionrepair.com/apple-watch-1...
Esta resposta foi útil?
Pontuação 2
I had the same problem, and after weeks of searching the web I eventually bought an iCloud locked apple watch off eBay, since they're rather cheap (I got mine for about 100$). I would not recommend it 100% though, since iCloud locked devices have a high chance of being stolen.
I repaired mine in august and havent had any problems since, its a rather simple repair. I would recommend buying thin adhesive strips though, because my screen keeps loosening from the frame.
Hope I could help
Pontuação 1
hi you can get a lcd screen and digitizer assembly here, very reasonable price
Pontuação 1
Hey, you can purchase a good reliable lcd/screen display/digitizer for the Apple Watch 1 42mm Band at Repair Parts Plus. Here is the link! Also a very reasonable price! http://www.repairpartsplus.com/Glass-Tou...
Pontuação 0
1 comentário:
Thanks! But is there somewhere with a lcd+digitizer combo? Because I haven't seen or heard of someone being successful in removing the digitizer to reuse the lcd since they are glued together.
por
Adicionar a sua resposta
Benjamin Busath será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 4,266
