Ir para o conteúdo principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Perguntas Visualizar todos
Shut down automatically after 3 mn
Hi,
MBP 2010 15 "goes off after the session starts about 3 minutes!
What I did:
  1. Reset nvram and smc
  2. "Apple" + R repair hd
  3. "Apple" + S fsck -fy
  4. Starting without extensions
  5. mounting another HD instead of the first
... always the same pb!
It does not hot, the 2 fans work
  • HD flex problem?
  • Another solution ?
thank you in advance for your help
Update (11/13/2016)
MacBook Pro "Core i7" 2.0 15" Early 2011 2.0 GHz Core i7 (I7-2635QM)
  • Intro. February 24, 2011 Disc. October 24, 2011
  • Order MC721LL/A Model A1286 (EMC 2353-1*)
  • Family Early 2011 15" ID MacBookPro8,2
  • RAM 4 GB VRAM 256 MB*
  • Storage 500 GB (5400 RPM) Optical 8X DL "SuperDrive"
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Was the MagSafe charger plugged in and was it Green?
When the system goes down does the Caps Lock LED light when you hit the Caps Lock key?
Are you able to see the faint image of your desktop when you shine a flashlight through the Apple logo in the lid?
por
Also please identify your exact model. Plug in your systems SN here: EveyMac - Lookup then paste the systems URL here for us to see.
por
Adicionar um comentário
1 resposta
Solução escolhida
Common GPU fault on the 2011 models, see https://www.apple.com/uk/support/macbook...
Return it to Apple before the end of the year, and they will fix this FOC
Esta resposta foi útil?
Pontuação 1
4 comentários:
Sorry but is not a GPU fault .... tested (Genius Bar), maybe an another way ?
por
Check the inside of the Macbook for liquid damage
por
No liquid damage....
por
I would recommend taking it to someone who can properly diagnose this, could be anything (something on logic board, SSD, software, etc). It is difficult to diagnose these without looking at this
por
Adicionar a sua resposta
Mikhrych será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 193
