Ir para o conteúdo principal
No engine light on dash
having problem engine light will not turn on with key on have two of the same trucks one does the other does not and i cant read the codes
Esta é uma boa pergunta?
Pontuação 0
3 comentários
miz4getful, See Brandon B. and oldturkeys answers above or Re POST year, make, model,engine, transmission and complete question so we, here at ifixit can answer your question effectively.
por
@lpfaff1 really? Another Canuck! Well, greetings from an expat.
por
Thanks for the greeting oldturkey03, all the leaves are down, you know what comes next, have a great day.
por
Adicionar um comentário
1 resposta
Solução escolhida
miz4getful, check the bulb for missing/loose/burnt out(exchange it for a known good working one and check the instrument cluster back side for damage, burn mark,corrosion, solder joint break, etc. and if OB2 port is not working check your cigarette lighter fuse for being blown. Good luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
miz4getful será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 120
