Ir para o conteúdo principal
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
Dust in camera lens
There is a spec of dust in my rear-facing camera - everything else is fine. Should I get a new camera replacement or will blowing a can of compressed air once I'm in do the trick?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
before replacing the entire camera try opening the camera and cleaning between the lens and the lens cover. I recently had a s5 that had an unusual blue tint to the photos it took when I bought a new camera for it. took it apart it turned out to be the protective cover was never removed from the lens at the factory . So maybe the dust is just between the lens and the glass cover on the case. Hope this helps
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
David Ocampo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 345
