Ir para o conteúdo principal
O Acer Iconia Tab 8 A1-840 é um tablet Android de 8 polegadas com Wi-Fi, 16 GB de memória flash e 2 GB de RAM. A Acer lançou o Iconia Tab 8 A1-840 em 2014.
Why won't my device charge?
I have plugged the charger into the device and into the outlet but it won't charge.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I have the same problem.. I didnt notice it was drained that night but i charge it for 6 hrs but theres no light that shows its charging.. And the tab and its charger is so cold not hot .
por
Adicionar um comentário
1 resposta
Solução escolhida
There might be several reasons the device is not charging. The charger or the USB might be defective. In order to fix the problem, plug the charger into a different adapter. If this does not solve the issue, check to see if the USB port is damaged. Replace the USB port if it is broken. For more information, please refer to the troubleshooting page.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 6,757
