Ir para o conteúdo principal
The G3 Controller is gamestop's version of a gamecube controller, equipped with A, X, Y, Z, B, Turbo Button, joystick, C-stick, left and right triggers, and a directional pad.
Why is my controller moving the character when I am not
My controller causes my character to move when I do not move the control stick. Is it dirty or is it just a bad signal?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Turns out there was an error when the console recognized the controller so I just unplugged it and re-connected it to the console.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Often times, disconnecting the controller and blowing into the connection port on both the controller and console can fix this problem.
Esta resposta foi útil?
Pontuação 1
Pontuação 0
It may be dirty or your joystick may be misaligned. I recommend you check out our joystick replacement guide, and use the steps to clean out the area and then reattach your joystick. If the problem still persists it may be a problem with your motherboard.
Pontuação 0
Adicionar a sua resposta
Andrew Gonsalves será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 514
