Ir para o conteúdo principal
Modelo A1046 ou A1095 / resolução de tela de 1280x854
Insulating sheet for Hard Drive
I have a PowerBook G4 without a hard drive. I obtained a replacement drive but I had no white-ish plastic sheet to insulate the circuitry from the components inside the body of the laptop, which I'm pretty sure would short something if exposed and in contact with each other.
Unfortunately, I thought of placing a cut piece of anti-static bag under the hard drive, and while I'm not positive this was the cause, the drive was dead (clicking on initialization, no booting) within 12 hours. Sad! So I don't think I can use that method.
Is there anywhere to get that plastic sheet or is there something suitable around the house? Parchment paper, maybe?
I'm really not interested in accidentally killing another increasingly rare hard drive.
Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
That's going to be a tough part to find. An alternative would be the MacBook Hard Drive Bracket which I think would be easier to find. MacBook Hard Drive Bracket
Imagem de Includes metal shield and four hard drive screws.
Produto
$29.99
Esta resposta foi útil?
Pontuação 2
1 comentário:
That is an excellent suggestion, assuming it is thin enough, which it looks like it is. Only other issue is... there aren't any. Maybe I can scrounge one. Thank you all the same.
por
Adicionar a sua resposta
Matt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 395
