Ir para o conteúdo principal
The Dell Inspiron 1100 was a low-cost consumer laptop released in 2003.
9 Perguntas Visualizar todos
Laptop will only stay on if pluged in.
The laptop runs fine when I have it plugged into the wall, but as soon as I unplug it it shuts down.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Replace the battery and it should work
Esta resposta foi útil?
Pontuação 2
It's possible that the battery is not charged enough to remain on without being plugged in, so check that first. If it seems to be fully charged or is not charging at all, then replacing the battery might be necessary.
Pontuação 0
Adicionar a sua resposta
alex tjersland será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 112
