My speaker wont turn off it keeps flashing a red light
Esta é uma boa pergunta?
Remove the plastic plate on the end with all the connection ports. I used a very small flat head screwdriver. Once opened, look inside with a flashlight and you'll see a small plug. I used very small needle nose pliers and just unplugged it, waited a few seconds and plugged it back in. Be careful not to damage any of the other parts. This allowed me to turn it off manually. Once you've done this, replace the plastic end piece and you can start from the beginning. This helped me. I certainly hope it solves your issue as well.
Esta resposta foi útil?
worked it, thanks
Absolute legend, thank you so much my freind, worked perfect!
You are the Legend, mate!
it's worth really thanks a lot. your genius
Brilliant - mine had frozen in on position but not reacting to any of the buttons, took your advice and all spot on again - top man!
Thank you this also helped me
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Duração total: 7,235
