heater blowing cold air
2008 Jeep Liberty
ac working good. heater blowing cold air. coolant level is good. temperature gauge in good level. floorboard not wet like other autos I've had that had bad heater core.
Esta é uma boa pergunta?
2008 Jeep Liberty
I would take a look at the actuator. Here's a very good answer on this with diagram on it:
Esta resposta foi útil?
Take the two hoses near the fire wall to the heater core off and flush it out, make sure to flush out in reverse, so as not to push obstruction further into the heater core.
Take a water hose and flush it out till clear of obstruction
Most likely be the resistor behind the glovebox. Very common issue
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 35,236
