Ir para o conteúdo principal
A laptop computer manufactured in 2005, by Compaq.
3 Perguntas Visualizar todos
Why is my laptop screen blue?
I turn on my computer and it seemed to be working fine and the next thing I knew the screen was blue. What's wrong with my computer?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If the blue screen occurs at the same point each time you use it it could be errors on the hard disk. Power down the computer and perform a scan on the hard disk through windows. Be prepared because this can take several hours. If you still are encountering problems after this then the hard disk is most likely physically damaged and will need to be replaced. Here is a link to the troubleshoot guide for this computer: Compaq Presario V2414NR Troubleshooting
Esta resposta foi útil?
Pontuação 2
More information would be very useful. Did the blue screen appear during use or did it turn on to that? Has anything happened to the computer recently? Any repairs or upgrades, drops, water spills, etc?
Pontuação 0
Adicionar a sua resposta
Solomon Abioye será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 454
