Ir para o conteúdo principal
A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
16 Perguntas Visualizar todos
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
por
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
por
Adicionar um comentário
1 resposta
Solução escolhida
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sony Cyber-shot DSC-HX20V Outer Case Replacement
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 1,074
