Tablet will not charge
Cannot turn my tablet on and it will not charge so i cannot turn it on no battery life
Esta é uma boa pergunta?
Samsung have issue if your battery is to week to charge . To fix this all you need to do is disconnect the battery and then reconnect then hook it to your charger and charge it . This guide will help with opening the tablet.
Samsung Galaxy Tab 7.0 Battery Replacement
Skip step 10 as your not actually going to remove the battery. Hope this helps
Esta resposta foi útil?
Your charging Port might be bad try to replace it.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 210
