Ir para o conteúdo principal
Black and Decker Cordless 18 V Drill Model PS1800. Has 330 inch-pounds of torque, and a 32-position clutch. Released in 2006.
4 Perguntas Visualizar todos
Drill bit is falling out
I am trying to secure my drill bit but it falls off when I am using the drill. What do I do?
Esta pergunta é pertinente?
Pontuação 0
1 dos comentários:
student, iFixit Technical Writing Project
por
Adicionar um comentário
1 Resposta
The Black and Decker PS1800 uses a two-sleeve keyless chuck for holding the drill bit. In order to tighten the chuck you firmly grip the inner ring with one hand, while turning the outer ring clockwise with the other hand. Tighten the chuck as much as possible before use. Also make sure that the drill bit is securely between the teeth of the chuck and not at an angle. If the drill bit still will not tighten then the chuck could be bad and will need to be replaced.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Arnold Morales será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 40
Duração total: 7,123
