Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Having problems replacing battery in iPhone 4S
A friend sent me an iPhone 4S and said it worked. When I received it, however, it would not turn on. I thought the easiest and cheapest solution would be to replace to battery, so I ordered one. Once I opened the phone though, the battery replacement was not the simple choice I thought it would be . To top it off, my cat seemed to like playing with the tiny screws and I could not find them. Where can I get such small screws (and whatever other small parts that might have been lost), and what do I need to do to get the replacement battery in (hopefully that is still the problem)?
Thanks for any help.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Phone should be able to turn on without the screws installed.
por
Adicionar um comentário
1 resposta
iFixit sellsiPhone 4s screw set.
However, as @Ben noticed, the phone should be able to turn on without the screws installed. You should have removed only a few screws and no other part to access the battery.
Hope this helps !
Vincent
Imagem de iPhone 4S Screw Set
Produto
iPhone 4S Screw Set
$9.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Gary Beeman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 67
