Ir para o conteúdo principal
Repair and support information for HP Laptops, designed for home and home office use.
1042 Perguntas Visualizar todos
Pergunta encerrada
My battery is 0%, plugged but not charging - Windows 7
Hi guys,
I need your help.
I am using HP Pavilion laptop and it has windows 7. It gives me error, battery plugged in but not charging.
I have tried to uninstall Microsoft ACPI-Compliant Control Method and then tried to update the driver, but on no avail. It's not a hardware problem. Battery is new.
I can't remove charging pin because my battery is at 0%.
Need assistance.
Esta é uma boa pergunta?
Pontuação 9
7 comentários
What model laptop do you have? Pavilion simply describes the line.
por
hp Pavilion dv6
por
I hаd a similar іѕѕuе, Mу laptop battery wasn’t charging when plugged in.
Fіnаllу I mаnаgеd to resolve thе problem.
Follow thіѕ guide hеrе: http://bit.ly/batterychargefix
Hope thіѕ helps
por
Hi guys,
I need your help.
I am using HP Pavilion(model 15p248ne) laptop and it has windows 8. It gives me error, battery plugged in but not charging.
I need your help because I have a bad financial situation and I can not spend moneyplease guide meThankful
por
I had the same problem...I researched everything and tried them all but none of them worked. I need to purchase and new battery and new adaptor as well..and now the problem is fixed and battery is charging
por
Exibir mais 2 comentários
Adicionar um comentário
5 respostas
Pergunta mais útil
Your battery needs 'some' charge in it before it gets detected and used by your laptop.
Remove the battery, press and hold the power button for 20 seconds to remove and static energy and then connect the adapter and power on your laptop without the battery. Now when the laptop is running, insert the battery (don't worry, it's not dangerous). Now your battery will get detected and start charging.
Reason for this happening:
Your laptop adapter powers your laptop+charges a low power battery. Unless it detects the battery (which it doesn't when it's at 0%) it doesn't charge it.
EDIT:
Hi,
I had a few people telling me that this solution didn't work for them and asking what else would be possible. I'd like to let you know that an old laptop battery of mine was having a similar problem for its 2nd replacement of a third-party battery (the original batteries are no longer in the market).
This solution did not seem to work for me as even after doing the above trick, it would "seem" to be charging but actually wouldn't.
Today, I took a different approach and kept using my laptop with a Linux OS (Kali Linux if anybody would like to know) The OS kept trying to estimate how much battery power was left and how long it would take to full charge. It couldn't detect as usual. After about an hour of usage, it could tell me that there was 1% of charge in the battery. This has not happened before and I decided to switch off the laptop and kept it plugged in to the power socket.
2 and a half hours later, it's at 85% now! I've never had the patience to try this solution as I never thought it would work. I'm using the laptop now to type out this answer without any power adapter plugged in and it's going smooth till now. It's now at 79%.
I'll continue to drain the battery till say 10% and charge it up to 100% for the next few days and hopefully, things should go back to normal :)
Please try this solution out when time permits. I nearly bought a 3rd battery again.
Esta resposta foi útil?
Pontuação 7
23 comentários:
Thankyou Sam! it is helpful.
por
Your solution worked. Thank you.
por
hi, I did as you said, at first it charged for 3 seconds! but suddenly it stopped charging as before. Then I did you recommendation again and it charged again for 3 seconds! and suddenly stopped charging. what should I do? (my battery was completely healthy before this respectively)
por
the solution is not working what should I do?
por
This solution doesn't always work. Like, if you have an old battery, you will definitely need to get a replacement (don't try opening it up and charging it manually as it's risky even if you're experienced). I have a 10 year old laptop that would work with the above method earlier, but since the past 5 years, needs a replacement.
Try getting a 3rd party battery that comes with a year warranty if the model is no longer available from the OEM.
por
Exibir mais 18 comentários
Have you tried a Live CD for like Ubuntu or some other Linux Version. Try that to see if it charges the battery or not. If it doesn't you might have gotten a bad New battery, or worse your laptops charging circuits might be fried.
Pontuação 2
See if your battery is part of the recall program. You may get a free battery.
http://www.hp.com/go/batteryprogram2018
Pontuação 2
Everyone needs a bootable USB plug with DOS.
It boots in 10seconds, then doesn't do anything.
But, if your charging circuits are working properly, it will goose-start the old Li-on batteries.
I found that a dead battery (0 volts) will charge up to something (+volts) in seconds.
However, it will not retain that voltage very long. The older it is, the shorter the time.
That explains why it may light your flashlight, but almost immediately go dim.
Most charging-circuits are the goose-start type where they give the battery a jolt, then measure, then another jolt, then measure. The higher the measure, the less the jolt. Until a smooth voltage is attained.
Some laptops will actually show the charging light 'jolting' the battery.
Now that I told this story, ignore it.
Li-on batteries burn so hot, and explode so violently,,, you have no idea.
Replace the old battery with a know good battery. ( That excludes a 'new' battery.)
This will show if the charging circuits are working properly.
Any reputable repair shop can easily do this.
Pontuação 0
3 comentários:
This discussion should be CLOSED.
It is old, and may lead novices to the DarkSide (pun intended)
por
It actually needs to be closed, Tom. I have no idea how to though. Help? :)
por
Thanks sam bhai. it is helpfully
Your solution worked. THANKS
por
Add your answer_________________________________DarkSide will be eternally grateful.
Hey Darkside ! Are you eternally grateful ? Did you replace that new/dead battery ?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 130,942
