Ir para o conteúdo principal
2.3L 4cyl or 3.0L V6, 6th Generation
The engine will not turn over
Hi my name is big black 52 I have a 2002 Honda Accord I put a new computer in now the engine will not turn over can anyone help
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@bigblack52 how did it work before you replaced the computer and why did you repalce it? What engine and what transmission does your vehicle have?
por
Adicionar um comentário
2 respostas
Solução escolhida
If the engine does not turn over at all its not the security being on . the security would allow the engine to crank but not fire. This sounds like a grounding issue. check your grounds at the battery , to the motor, to the body . Also wouldn't hurt to check the solenoid . However LPfaff is right in that once the car will crank I may not start because of the Honda security system . It will need to be programed to accept the chip in the key
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
@bigblack52 , Anthony, Is your security on, If you put the computer in the car yourself, chances are you may have to take it into the dealer to have computer/ ECU flashed / programmed to your vehicle. Good luck.
Pontuação 2
Adicionar a sua resposta
anthonyjackson841 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 379
