Why is my timing chain loose?
I got valve cover off passenger side head and was checking out the timing chain and it was tight. Then turned crank to where timing chain moved about 2" and checked it again. It was loose. Is this normal or do I need to fix something?
2000 expedition 5.4l
Esta é uma boa pergunta?
1 comentário
@weelee why did you check the timing chain? What are the issues with your Ford? Anything related to the timing going on? How many miles are on your engine?
por oldturkey03
