Ir para o conteúdo principal
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
Can the SSD be switched out?
Can the SSD be switched out and upgraded ?
Esta é uma boa pergunta?
Pontuação 8
Adicionar um comentário
7 respostas
Pergunta mais útil
Looks like the entry level 13" isn't soldered
OWC noted the following points in its teardown.
– Bottom was more difficult to remove than previous generations, but it was not glued.
– Speaker module needs to be removed to pull SSD back.
– SSD had very strong tape covering the interface port.
– Laptop automatically turns on when you open it regardless of pressing power button.
Esta resposta foi útil?
Pontuação 2
2 comentários:
If you review the OWC vid you'll also see the SSD module is very different from the older systems and it looks like a custom part! So, even if its removable, it will be a while before we see a 3rd party option.
por
@danj Yes I saw that! Hopefully the wait isn't as long as it was for the Retina models!
por
http://blog.macsales.com/38440-ssd-in-la...
Pontuação 1
Yes, Please look at
Pontuação 1
Yes. But so far no one has made an SSD that is compatible with this model, the first few will begin to pop-up within the next few months.
Pontuação 1
Yes is it removable.
Update (10/31/2016)
Pontuação 0
2 comentários:
Do you have a back up link on this?
por
I would like to know where you got this information. Nothing on the internet says Soldered, but I wouldn't put it past them
por
Anyone here who knows the pinout of the new SSD?
Pontuação 0
Adapter for MacBook Pro 13” 2016/2017 nTB
https://www.globalmac.cl/Adaptador-SSD-M...
(Chile)
Pontuação 0
Adicionar a sua resposta
benkuza será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 8,129
