Ir para o conteúdo principal
Wood and wheels. There are a variety of different types of skateboards used for different purposes. The basic types of skateboards can be categorized into cruiser boards, longboards, and standard trick boards.
20 Perguntas Visualizar todos
I put penny wheels on my skateboard and it wont turn
So i just bought these penny wheels to put on my skateboard btw my skateboard has skateboard trucks. And i just want to cruise on my board not do tricks so i replace my wheels and when i put them on it wont turn what should i do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
So the question is, will it not turn when you stomp on the tail pad? or does it not turn when you lean into the board?
Either way, this is an easy fix! If you aren't turning when you lean into the board, you need to loosen the kingpin nut on your trucks (http://www.veniceskateshop.com/pages/ska...). Turn the nut left using a socket wrench or a special skate tool.
If your wheels aren't spinning, and you are having trouble turning by the stomp pad, check the bearings! The bearings are the little metal doughnuts within your wheel. Did you get new bearings when you bought new wheels? If not, maybe get some new bearings.
Best of luck!!!
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Frake Jake será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,018
