Ir para o conteúdo principal
The Sony Xperia C5 Ultra (dual) is also known by the model numbers E5533 or E5563 and was released in August 2015.
8 Perguntas Visualizar todos
Sony Xperia C5 Ultra touchscreen is malfunctioning.
Hello everyone.
I would really appreciate some help with my Sony Xperia C5 Ultra Dual since my screen is going crazy. The problem includes moments of normal function before it becomes fully irresponding or with Ghost touch.
Before you ask, I have removed an screen protector, rebooted the phone, removed the SD card and did a couple hard resets before realizing that none of these helps.
Thank you in advance!
Esta é uma boa pergunta?
Pontuação 5
3 comentários:
Brother, did you solve the problem? Im with the same situation, it is get me crazy!
por
are there any updates that need to be done. also i would try doing a full restore from a stock rom. not a hard reset. you can’t get more pure then reloading your system from scratch. any physical damage to the phone?
por
i also have the same problem, mine was due to rain but the effect appeared maybe almost half a year before it malfunction
por
Adicionar um comentário
4 respostas
I have the same problem but I always solve it cleaning the screen with a handkerchief and screen cleaning solution.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Really?? Does it help to bring it back to the normal state?
por
Definitely not, I have the same problem and cleaning it doesn't help at all. You should always use soft parts of your fingers in order to get the screen to respond.
por
I need for my sony Batteries?
Pontuação 0
2 comentários:
هاتفي عند تشغيلة تصبع الشاشة مقطعة ولا يظهر التطبيقات
por
الحساسات انضربن بسبب الماء
Pontuação 0
اهلا وسهلا من فظلكم مشكلتي في الهاتف لن يشغل فقط ضوء احمر في الشاشة عند تركيب الشاحن شكآ
Pontuação 0
Adicionar a sua resposta
G008 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 3,539
