Ir para o conteúdo principal
This is the Dell Latitude E5410 14.1" Essential (1st gen Core i3/i5/i7), which was released in 2012.
What if no sound is coming from my laptop?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@denysd16 , Check that your system audio is not muted and that sound is turned up. Check that the media player you are using has the sound up. Ensure no external audio devices are plugged into your computer. Check the attached links for more things like updating, checking drivers, etc., that can be checked to correct your Dell Latitudes sound issue. Good luck.
https://www.techwalla.com/articles/how-t...
Dell Latitude E5410 Troubleshooting
http://en.community.dell.com/support-for...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Denys Diaz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 390
