Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
Esta é uma boa pergunta?
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
Esta resposta foi útil?
You need a new Turn Signal Switch, relatively cheap part
Bulb replacement solved the problem
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 121
1 comentário
Bulb replacement worked. Thank you
por Dennis Johnson
