"Accessoire not supported" after replacement
Hi,
There was a bit of dust inside my charging dock, and it was so hard to get out so I replaced my charging dock.
Now suddenly it says "accessoire not supported", even if I use different cables and charing ports...
What is the problem here?
Thanks
Esta é uma boa pergunta?
2 comentários
The charging dock might be a faulty replacement one. Even if it's so hard to get dust out keep trying on the old one. I'm sure you will get it out. Just don't break the pins inside the charging dock.
por Ben
If it's not a faulty flex u may have damaged the ic's by the charging port connector on the board.
por c9679
